    Apr 2005
    Denmark
    Hi.
    How come that every time I try to open any sort of divX file in my Sony Vegas 6.0 that the videostream and audiostream are not syncronized.
    USA
    Does it have MP3 VBR audio? That's the most common cause of sync problems with Xvids or Divx. Drop it into VirtualDub Mod and you should know immediately. Then, save it out as a WAV with full audio processing and you can convert it to MP3 CBR or other audio formats that Sony might accept.
    Apr 2005
    Denmark
    I used Gspot to get infomation about the file:
    Audio:
    Name: 0x0055(MP3,ISO) MPEG-1 Layer 3
    info: 44100Hz CBR 128 kb/s total (2 chnls)
    So I guess it's not a MP3 CBR-problem or what?
    Apr 2004
    Miskatonic U
    Are you using matching framerates between the project and the avi file ?
    Read my blog here.
