i want to convert 8 episodes of buffy to one dvd with menus and subtitles.
i tried convertxtodvd(good software) but i can put just 4 files in it.
can someone please give me a way to burn 6 or more files to one dvd with menus and subtitles..and its easy to do it.
thankx alot!
your my only hope.
Results 1 to 16 of 16
Take a look at DIKO. It might be what will work for you. A guide: https://www.videohelp.com/guides.php?guideid=835&howtoselect=3;6#835
Hmmmm .... may be a restriction of the trial version. Maybe try the old freeware version of its predecessor, divxtodvd (0.5.2) ?Originally Posted by reaper666
Details, manOriginally Posted by reaper666
"An error" could be anything, and we can't see your screen from here. Could you at least detail what the error was ? or alternatively screencap and upload it ?If in doubt, Google it. -
yeahh i know..but how can you explain it that i can put 4 avi files in one dvd? and it looks awasome...
your sure that isnt a way to put more than 4 files (400mb each) with convertxtodvd? -
I told you earlier .... I've put 45 files in at one point but I am using a registered licensed version though.Originally Posted by reaper666
Does it give you an error ? Is it possible that there's something wrong with file no 5 causing it to drop out ?If in doubt, Google it. -
in convertxtodvd i put more than 4 files..and it shows me at the bottom 5.76 Gb...
i tried using Diko with dvd styler..i tried to convert 6 files i did menu..and after 12 hours (too much time) it gave me no dvd image or something like..just alot of "mpa" "mpv" and "mpg" files..
what can i do with them? -
Author the mpg files. mpa is audio, mpv is video, and mpg is probably one of the mpa files muxed with one of the mpv files.
Hey .... I don't suppose you tried looking in the Guides section did you ?
https://www.videohelp.com/guidesIf in doubt, Google it. -
i tried...trust me..i "author" them with dvd styler..but the sound wasnt syncronize with the video..the video was too fast.
i think im pretty tired of all this convertings...
i think i will pass the menus and all the things..
i need an easy way to burn 8 files with subtitles to dvd...point to me the right and easiest software.
thankx!
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 15:53 -
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 14:27 -
Can you solve my choppy video problem?
By imrealdumb in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2009, 21:44 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 06:42 -
Unable to solve a boot problem, really need some HELP.
By blinky88 in forum ComputerReplies: 5Last Post: 24th Apr 2009, 17:17
