When putting together music or video compilations I frequently throw in audio from odd sources like old documentaries, TV news, etc. which have very different volume levels and cause a lot of volume control fiddling for the end user.
I've usually relied upon my ears and Goldwave's volume settings to tweak individual files to where they more or less match others on playback, but I'm looking for a faster and more professional sounding result so I've been exploring the use of the Max and Match settings in Goldwave. Questions:
1. Goldwave help says don't use Max and Match on the same file because they cancel each other out on that file, but I'm actually using Max on every file to the same setting (full dynamic range) and then using Match on a whole bunch of audio files at once to get the same average volume level. Do you see any reason why this won't work? I'm careful to view all the files individually to find the lowest average volume and then I set Match to that level to avoid clipping.
2. Itunes has a "Use Sound Check" check box for burning CDs. Is this supposed to work the same way as the Match setting in Goldwave? It doesn't seem to work very well according to my ears.
Thanks.
"The fact to which we have got to cling, as to a lifebelt, is that it is possible to be a normal decent person and yet be fully alive." - George Orwell
Have you tried Musicmatch Jukebox? There is a volume leveling feature.
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
how to achieve max quality in fairuse wizard, x264 settings
By llmercll in forum Video ConversionReplies: 21Last Post: 17th Jan 2009, 09:17 -
60 Inch DLP Max 1080i Settings ??
By ofield1 in forum DVB / IPTVReplies: 12Last Post: 29th Feb 2008, 19:54 -
goldwave help
By natty in forum Newbie / General discussionsReplies: 16Last Post: 23rd Feb 2008, 03:12 -
goldwave
By natty in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2008, 06:25
