hi i used dvd decrypter to to get movie files from a dvd but the .vob files have little lines now and then in the movies the quality is is great except fot this sorta like digitation, they go across and the the video plays i dunno if that is called interlacing?
is there a program that can get rid of this, etc?? thanx in advance![]()
Perfectly normal interlacing. DVDDycrpter simply made an exact copy (minus encryption) of what was on your DVD. If you're making a DVD don't worry about them.
cool
so i just go ahead and make up my dvd will the lines disappear or does the dvd player not show them ?
When you play a DVD on your TV you will see one field at a time, seqentially, so you won't see the interlace comb artifacts.
When you look at the same video on the computer you see both fields at the same time (unless tje player is deinterlacing). Hence you see the interlace comb artifacts.
Video Scan Lines
By sunnah in forum Newbie / General discussionsReplies: 7Last Post: 10th May 2011, 21:05 -
Why am I getting these strange lines in my video?
By Captain Satellite in forum Newbie / General discussionsReplies: 19Last Post: 7th Mar 2009, 12:16 -
Lines of degradation in video....
By mpgery in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2008, 21:17 -
Will sending video from my TV through my vcr/dvd player get rid of lines?
By Darkstraw in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 00:47 -
Why are there lines in my video?
By Mysteriouskk in forum Video ConversionReplies: 8Last Post: 6th Dec 2007, 22:30
