I need to convert 2 avi's to the same format so i can join and burn them to a dvd.
one was from a digital camera and so came off as mjpg avi's.
The other is a dv avi straight from a digital video camera.
To join them i need to get them the same. I know HOW to do this using virtualdub, but i cant decide which is the best format to convert them to.
I want one that will simple get them the same format, without losing any quality. What is regarded as the best codec for this?
Hi bohboh,
Your choices are either the Morgan MJPEG (US$20) or the Panasonic DV Codec (free) - either of which provide excellent quality.
So I'd say go for the free one...
And, to boot, I've used it before with VirtualDub with no problems.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I have the dv codec installed and that was the first i tried, but i cant covert it, i get the following message...Originally Posted by daamon
Cannot start video compression
The source image format is not acceptable
(error code -2)
I assume that it cant convert mjpg to dv codec. -
Ok, i have downloaded morgans codec.
There are a load of settings, should i be changing any? Assume i dont, -
Yep, think thats the problem. In gspot it says that the mjpg's are 320x240 . I have had a look in virtualdub, how do i go about changing it?Originally Posted by guns1inger
Yep, spotted that under video filters.Originally Posted by redwudz
Since i am scaling up i gave it a black border so's to not pixelate it too much. Virtualdub is pretty much all you need when it comes to video editing, especially as its free.
v210 AVI codec
By christianolovesvideo in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2009, 14:59 -
DV-avi codec error????
By crb119 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 12th Jun 2009, 07:49 -
DVD to AVI but no codec
By Cazz in forum DVD RippingReplies: 6Last Post: 27th Mar 2009, 10:10 -
How to get avi codec for mac????
By balonglong78 in forum EditingReplies: 14Last Post: 9th Feb 2009, 20:13 -
The best AVI video codec
By hzgg2 in forum Video ConversionReplies: 1Last Post: 2nd May 2008, 17:19
