i get an error saying "could not copy avisynth.dll to system directory - close down all applications that use Avisynth, and be sure to have write permission to system directory, and try again".
ive googled it, and looked on the site. ive deleted all avisynth files (did a search on my computer, including hidden files), and all avisynth registry files. i looked in my process list, and i made sure there are no programs running that use avisynth. ive tried rebooting and i still get the same error.
anyone know why?
maybe i dont have write permission to the system directory? if so, how do i do that?
Results 1 to 12 of 12
i am the admin i believe. under user accounts, it says "computer administrator".
i unchecked "read only" for the system32 folder (and all the files etc inside... is that ok to do?) and it worked.
i found no results that worked from googling it. i searched on yahoo and found a site that suggested it.
thanks for your help anyway. -
completely off topic, but i didnt want to start a new thread.
in DVD Rebuilder Pro, i can't seem to click the Preview/Edit button. anyone know why?
is it because im using 1 click mode? i cant see if thats why, as im currently encoding. -
really strange... i had exactly the same and your solution worked.
I also tried the new version of april 2, which didn't work either. I'm system admin, I ran windows in safe mode, nothing helped except this. Makes no sense but w/e
64-Bit AVISynth wont install
By killerteengohan in forum EditingReplies: 1Last Post: 10th Mar 2012, 23:55 -
Unable to install avisynth: Error opening file for writing
By ximon in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2011, 18:52 -
can't install Avisynth due to the devil.dll
By cemman in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2009, 06:18 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
How to install plugins for Avisynth?
By 1gnition in forum Capturing and VCRReplies: 4Last Post: 19th May 2007, 20:06
