Hi: I know that this is a stupid question. I was able to create menu before using NeroVision Express 3.SE Version 3.1.0.11. But now, I cannot get to this screen: http://enscreenshots.softonic.com/s2en/28000/28290/0_visionexpress_menu.jpg
On the first page, it doesn't contain the MAKE DVD link anymore!
How is your DVD recorder connected to your computer? If it's a removeable drive that might be the problem. NERO checks for attached hardware when it starts Nerovision and if the recorder isn't found then it won't offer the Make DVD option.
There may be other thinks involved as well, but the menu screen should show up unless you've selected DVD only instead of Titles or Tiles & Chapters in the drop down box.
BTW I have a problem with Nerovision 3 importing discs with sound at 33% and I have to manually change the sound level. It appears they are aware of this and plan to fix it in a future update. The problem isn't there in the current version of Nerovision 4.0 -
yeah, it's removable, but it is already connected before i start Nerovision. it's really strange =(
thanks for info... if only i could make DVDs in the first place =D
NeroVision Express 3 does not have chapter buttons
By Brent G. in forum Authoring (DVD)Replies: 1Last Post: 9th Aug 2008, 00:45 -
DVD-RW VRO to DVD in NeroVision Express problem
By ecc in forum DVD RippingReplies: 1Last Post: 30th Jul 2008, 01:17 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 23:42 -
NeroVision Express 3SE: Return to the main menu?
By frankieg in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2007, 11:31 -
main menu music, nerovision express 3
By Reggie6966 in forum Authoring (DVD)Replies: 4Last Post: 10th Jun 2007, 08:00
