  1. I am using AviSub to integrate subtitles to avi which is great. Unfortunately this tool does not support Xvid files with MPEG Quantization. How to convert to H.264 Quantization without re-encoding the files? Thanks
    Wu
    Dec 2004
    Australia
    I assume that you mean H.263 and basically you can't. You need to re-encode. I would suggest using a Home Theatre Profile. Can't you over ride the DivX compliance check though? That way you could have MPEG quants even though they don't conform to DXN specs.
  3. Originally Posted by celtic_druid
    How to do that? Thanks
    Wu
    Dec 2004
    Australia
    I don't know. I don't use xsubs/the divx container. I assume divxmux has some kind of switch though.
