I am having a small problem that I am hoping someone might be able to help me with. I have been using AutoGK to convert some DVD episodes to AVI files. I recently "graduated" to using Gordian Knot because I felt that I would have more control over things. Well... I have been following the guide for Gordian Knot that is found on http://www.rita.lt/ to the LETTER, and I have even encoded my project more than once but I am still having the same problem. I set the file size for 300mb and I am encoding the file with Xvid. For some unknown reason, when the program is done encoding, I am getting a resulting file that is between 30-50mb instead of 300mb!! Again, I have redone this a couple of times and have followed the guide religiously! Obviously the resulting file looks horrible at 30-50mb in total size, virtually unwatchable. Any idea what I am doing wrong, and why the program is not converting this to the 300mb file that I told it to? I guess I should also point out that I am in fact saving everything in the same folder.
Have you tried adding an extra zero to make it 3000? Maybe that will make it 300.
Or maybe try to uninstall/reinstall the program and XVID?
That does seem weird, hope you get it sorted out. -
I'm pretty new to this so it's probably 'user error'.
Same problem as above - can't get Gordian Knot to produce files of the correct size.
In the case below - final AVI is only 16MB. Target size over 300MB. Final quality is terrible so it's not 'saturated'. Tried withg multiple DVDs save result. Tried reinstalling XVID - no change.
Tried adding a zero to the target size - no difference.
Log below.
Note the target size throughout.
Note how quick the second pass runs.
Any ideas?
Pretty please?
Anything else needed to diagnose?
Luke.
Log:
15/05/2006 1:03:34 PM: Job " 1 - Test_1.avi" started.
o Xvid - First Pass: D:\DVDs\DVDTest\Test.avs
o Xvid - Second Pass: D:\DVDs\DVDTest\Test.avs
x Mux Audio (disabled).
End of Job 1 ( 1 - Test_1.avi).
__________________________________________________ __________________________________________________ ___________________
Gordian Knot
Encoding Job Data:
Type: EncXvid_All
Container: Audio-Video Interleave (AVI)
Number: 1
Name: 1 - Test_1.avi
Platform: WinXP (5.1.2600).2
Files:
VirtualDubModExe: C:\PROGRA~1\GORDIA~1\VirtualDubMod\VirtualDubMod.exe
NandubExe: C:\PROGRA~1\GORDIA~1\nandub\Nandub.exe
AviFinal: D:\DVDs\DVDTest\Test_1.avi
AviMovie: D:\DVDs\DVDTest\Test_1_Movie.avi
AviCredits: D:\DVDs\DVDTest\Test_1_Credits.avi
MovieFS: D:\DVDs\DVDTest\Test.avs
CreditsFS:
Log : D:\DVDs\DVDTest\Test_1.log
Stats: D:\DVDs\DVDTest\Test_1.stats
Ecf : D:\DVDs\DVDTest\Test_1.ecf
Options:
Quality/DRF: 0
CreditsStart: 0
UseEcf: 1
CreditsIVTC: 0
CreditsAppend: 0
DeleteInterm.: 0
EnforceBitrate: 0
AntiShit: 0
Calculator:
VideoSize: 329994 kbyte.
Audio1Size: 26734 kbyte.
Audio2Size: 0 kbyte.
Overhead: 1670 kbyte.
AviSize: 358400 kbyte (350 mbyte).
FilesSize: 0 kbyte.
TotalSize: 358400 kbyte (350 mbyte).
Interleaving: vbrmp3
Bitrate: 1580 k(=1000)Bits/s
Frames: 42773
FPS: 25.000
Duration: 028:31
Quality: 0.327 bits/(pixel*frame).
CompCheck3: 0.000 bits/(pixel*frame).
CompCheck5: 0.434 bits/(pixel*frame).
Resolution: 672 x 288
Audio 1:
none.
Audio 2:
none.
1:03:34 PM: Audio 1, calc: 26734 kb
1:03:34 PM: Audio 1, disabled, no recalc. - you probably want to add this track later.
Adding this script to C:\PROGRA~1\GORDIA~1\VirtualDubMod\LastJob.vcf :
// $job "XviD First Pass"
// $input "D:\DVDs\DVDTest\Test.avs"
// $output "D:\DVDs\DVDTest\Test_1.avi"
// $state 0
// $start_time 0 0
// $end_time 0 0
// $script
VirtualDub.Open("D:\\DVDs\\DVDTest\\Test.avs",0,0);
VirtualDub.video.SetDepth(24,24);
VirtualDub.video.SetMode(1);
VirtualDub.video.SetFrameRate(0,1);
VirtualDub.video.SetIVTC(0,0,-1,0);
VirtualDub.video.SetRange(0,0);
VirtualDub.video.SetCompression(0x64697678,0,10000 ,0);
VirtualDub.video.SetCompData(3532,"AQAAALwCAACQsgg ARDpcRFZEc1xGb29kU291cmNlXFRlc3RfMS5zdGF0cwBjAGUAX ABUAGUAcwB0AF8AMQAuAHMAdABhAHQAcwAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAkAEAAEFkdmFuY2VkIFNpbXBsZSBAIEw1AABtAHAAbABlACA AQAAgAEwANQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAACQAAAChVc2VyIGRlZmluZWQpAABmAGkAbgBlAGQAKQAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAgAAAAAAAAAIERITFRcZGxESExUXGRscFBUWFxgaHB4 VFhcYGhweIBYXGBocHiAjFxgaHB4gIyYZGhweICMmKRscHiAjJ iktEBESExQVFhcREhMUFRYXGBITFBUWFxgZExQVFhcYGhsUFRY XGRobHBUWFxgaGxweFhcYGhscHh8XGBkbHB4fIQAAAAAAAAAAA AAAAAAAAAAAAAAAAQAAAAIAAACWAAAAZAAAAAAAAAAAAAAABAA AAAMAAAABAAAAAQAAAAAAAAABAAAAAAAAAAAAAAAAAAAAZAAAA PQBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAABAAAABkAAAAZAAAAAEAAAAKAAAAAQAAABQAAAAAAAAAA AAAAAUAAAAFAAAABQAAAAAoCgAAAAAAAQAAAAEAAAAeAAAAAAA AAAIAAAAAAAAAAAAAAIAAAAAAAAAAAAAAAAYAAAABAAAAAAAAA AEAAAABAAAALAEAAAAAAAABAAAAHwAAAAEAAAAfAAAAAQAAAB8 AAAABAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAA/wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAA==");
VirtualDub.video.filters.Clear();
VirtualDub.subset.Delete();
VirtualDub.SaveAVI("D:\\DVDs\\DVDTest\\Test_1.avi" );
VirtualDub.Close();
// $endjob
// $done
1:03:35 PM: Started Xvid - First Pass: D:\DVDs\DVDTest\Test.avs
1:13:49 PM: Finished Xvid - First Pass: Duration: 10 minutes, 14 seconds.
1:13:49 PM: Trying to open Log-file.
1:13:49 PM: Success: Log-file open.
1:13:49 PM: Encoded: 42773 Frames.
1:13:49 PM: Speed: 69.597 Frames per Second.
1:13:49 PM: New target size = 329995 Kb
// $job "XviD Second Pass"
// $state 0
// $start_time 0 0
// $end_time 0 0
// $script
VirtualDub.Open("D:\\DVDs\\DVDTest\\Test.avs",0,0) ;
VirtualDub.video.SetCompData(3532,"AgAAALwCAAALCQU ARDpcRFZEc1xGb29kU291cmNlXFRlc3RfMS5zdGF0cwBjAGUAX ABUAGUAcwB0AF8AMQAuAHMAdABhAHQAcwAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAkAEAAFNpbXBsZSBAIEwwACAAQAAgAEwAMAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAChVc2VyIGRlZmluZWQpAABmAGkAbgBlAGQAKQAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAgAAAAAAAAAIERITFRcZGxESExUXGRscFBUWFxgaHB4 VFhcYGhweIBYXGBocHiAjFxgaHB4gIyYZGhweICMmKRscHiAjJ iktEBESExQVFhcREhMUFRYXGBITFBUWFxgZExQVFhcYGhsUFRY XGRobHBUWFxgaGxweFhcYGhscHh8XGBkbHB4fIQAAAAAAAAAAA AAAAAAAAAAAAAAAAQAAAAIAAACWAAAAZAAAAAEAAAAAAAAABAA AAAMAAAABAAAAAQAAAAAAAAABAAAAAAAAAAAAAAAAAAAAZAAAA PQBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAABAAAABkAAAAZAAAAAEAAAAKAAAAAQAAABQAAAAAAAAAA AAAAAUAAAAFAAAABQAAAAAoCgAAAAAAAQAAAAEAAAAeAAAAAAA AAAIAAAAAAAAAAAAAAIAAAAAAAAAAAAAAAAYAAAABAAAAAAAAA AEAAAABAAAALAEAAAAAAAABAAAAHwAAAAEAAAAfAAAAAQAAAB8 AAAABAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAA/wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAA==");
VirtualDub.Close();
// $endjob
// $done
1:13:49 PM: Started Xvid - Second Pass: D:\DVDs\DVDTest\Test.avs
1:13:51 PM: Finished Xvid - Second Pass: Duration: 1 second.
1:13:51 PM: Speed: 31473.866 Frames per Second.
1:13:51 PM: Done.
1:13:51 PM: Movie = D:\DVDs\DVDTest\Test_1.avi
Total Encoding Time: 10 minutes, 16 seconds.
15/05/2006 1:13:51 PM: Job " 1 - Test_1.avi" finished.
Encoding 59.940 video to AVI with Gordian Knot!
By xxtreasuresxx in forum Video ConversionReplies: 10Last Post: 7th Jun 2011, 22:48 -
Problem On Encoding DVD to H.264 By Gordian Knot
By bugsboney in forum Video ConversionReplies: 6Last Post: 27th Jul 2008, 09:52 -
using Gordian Knot
By ricmetal in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:20 -
Gordian Knot help
By zookeeper525 in forum DVD RippingReplies: 25Last Post: 16th Aug 2007, 00:49 -
Auto Gordian Knot anyone?
By Lee82 in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 20:31
