    Apr 2006
    Hi,
    Having a slight problem with conversion. I had avis and using Winavi converted them into DVD format, I know winavi isnt the videohelps preferred program however it is quick and gives quality episodes. There would be no problem if I did not want a menu but I do.
    So once I have my DVD folder containing Video_TS Folder I create a new project in DVD Author. I open the video TS folder and it lists the avis as "Titles" So i had 3 titles. I added video to the track and pointed to one of the titles it then converted these to a MPEG2 file. I stupidly deleted the AVIs as I needed the disk space!
    When I had the finished product the audio was out of sync by about 1 second. The newly created files play in media player with no sync issues whatsoever. Because of the format of the mpeg files I am limited to what I can do as Virtualdub- Mpeg 2 will open however does not allow audio!
    I then ran the mpegs through Tmpengc and converted into DVD Pal using the wizard leaving everything as is just reducing the bitrate. I then ended up with the .wav and .m2v. I loaded these into TMPENGC and got no sound on the DVD at all never mind sync problems! I opened the wav files and its 42 minutes of nothing in relation to each avi file!
    Does anyone have any ideas as any help would be appreciated!
    convertxtodvd, it can create simple menus also.
    Apr 2006
    Perfect works a treat , thanks!
