I have a .mpg file that I'm trying to convert to .DV for use in iMovie. I am able to drop the file directly in iMovie, but during the import the quality seems to diminish. Attempting to convert with ffmpegx results in thee "finished..." but unusable file.
Streamclip converts the file but ffmpegx has trouble. Suggestions?
Here's the info:
Mac OSX static build for ffmpegX
Input #0, mpeg, from '/Users/xxxxxx/Desktop/MOV01228.MPG':
Duration: 00:00:21.8, start: 0.070000, bitrate: 10487 kb/s
Stream #0.0[0x1c0]: Audio: mp2, 32000 Hz, mono, 64 kb/s
Thu Apr 20 11:08:53 CDT 2006
fps: Video: mpeg1video, yuv420p, 640x480, 104857 kb/s
Codec type mismatch for mapping #0.0 -> #0.0
Tried that...
Thu Apr 20 21:53:45 CDT 2006
Input #0, mpeg, from '/Users/xxxxxx/Desktop/MOV01240.MPG':
Duration: 00:00:14.6, start: 0.070000, bitrate: 10482 kb/s
Stream #0.1[0x1e0], 30.00 fps: Video: mpeg1video, yuv420p, 640x480, 104857 kb/s
Output #0, dv, to '/Users/xxxx/Desktop/MOV01240.MPG.ff.dv':
Stream #0.0, nan fps: Video: dvvideo, yuv420p, 720x480, q=2-15, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
[dvvideo @ 0x444b70]Can't process DV frame #441. Insufficient audio data or severe sync problem.
video:14766kB audio:2761kB global headers:0kB muxing overhead 194.868880%
bench: utime=19.912s
Encoding completed on Thu Apr 20 21:54:15 CDT 2006
Different file this time?Originally Posted by fatespawn
Quite short. Is this duration correct, or a timecode break? To fix timecode breaks, use MPEG Streamclip's Edit menu.Originally Posted by fatespawn
14.7 seconds x 30 fps = 441 frames, so the last processed frame seems consistent with the timecode.Originally Posted by fatespawn
15 seconds of DV video should be around 50 MB, so there seems to be not enough video data, even for the 441 frames until the error. No idea why.Originally Posted by fatespawn
Yes, it's a different file... and a different computer....
But they're shot from the same camera and both using .9v of ffmpegx. The videos I have shot are short for testing purposes until I can get it to work consistently.
I don't mean to mix apples and oranges, but I just use what I have on hand. It yields the same results.
Streamclip converts the file seamlessly to .dv but ffmpegx seems to have troubles.
10482 kb/s, this seems a bit high even for an 640*480 mpeg file. Try to open your file with Mpeg Streamclip, then choose "Save as Mpeg..." (Or is it "Convert to MPEG..." ?). This has fixed a number of files from my Sony camera which had weird bitrate and file size. I can get up to a 4 MB file size decrease on an 18 MB clip !Originally Posted by fatespawn
I guess this may come from a bad muxing method.Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
Thanks for the suggestions. I guess what I was hoping to do was avoid Streamclip altogether. Streamclip seems to do a fine job of handling the video and allows me to convert to any of the supported formats including .DV for my use in iMovie.
I was just hoping to avoid another video program, but I guess ffmpegX just can't handle it properly.
-Fate
minted dvd with ding in silver part
By spiritgumm in forum MediaReplies: 6Last Post: 21st Jun 2011, 00:13 -
Doom 4!
By retroborg in forum Off topicReplies: 8Last Post: 12th Aug 2008, 06:02 -
Ding!! But zero kb file size
By johntay555 in forum ffmpegX general discussionReplies: 3Last Post: 3rd Jun 2008, 15:54 -
Doom 9 off the air
By AlanHK in forum Latest Video NewsReplies: 10Last Post: 2nd Feb 2008, 23:50 -
Ding but no file
By hotlunch in forum ffmpegX general discussionReplies: 4Last Post: 31st Dec 2007, 23:20
