i download movies from kazaa from time to time and would like to know does anyone know how to convert the files to mpeg. I've used a lot of converters and always get a error message does anyone do this and if so how do you convert them thank. help?
ok if u are using kazaa search in software VCD converter it is an exe file it is actually tmpg but is renamed vcd converter and it actually works not like some versions of tmpg i found on the net. hope this helps
Conversion help.
By yugub in forum Video ConversionReplies: 9Last Post: 18th May 2011, 20:45 -
Exactly what goes on in conversion?
By Haopengyou in forum Capturing and VCRReplies: 1Last Post: 2nd May 2011, 10:52 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 10:46
