Just upgraded to the new DVD Author Pro which has a few nice little features which I like, ie. Audio on the main menu. But when I use any program other than TMPgEnc 3.0 Xpress to encode AVI files to MPG files I get various errors. Such as,
file cannot be processed using file smart rendering
I prefer to use IMToo MPEG Encoder to convert my AVI files to MPG because its quicker and produces the quality i need,
I'm converting to MPEG1 and sometimes MPEG2, there are numerous settings in IMTOO that may make a difference but I cant seem to get DVD Author Pro to accept any MPG files converted using any program other than XPress. Have tried numerous others without success.
Got me thinking it is a way of them making sure you use XPress if you want to use Author Pro -
I use Tsunami DVD Author Pro as well and I can tell you that they do not force you to use Tmpgenc Xpress to create usable mpegs.
I create my mpegs using Avisynth and CCE. I also use VOB2MPEG to create mpegs as well as run all of them through VideoRedo to cut out commercials, ensure audio/video sync, etc.
I've never used IMToo Mpeg Encoder, but I can confirm that DVD Author Pro has no problem accepting mpegs created by the software mentioned above. -
I use motion Mpeg menus in TDA all of the time....I was always under the assumption that you just couldn't use AC3 in the menu?
I encode my little mpeg snippets with TMPGEnc Plus 2.5.
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 14:02 -
No sound in VLC, MPC, or Tsunami DVD Author
By ibzomie in forum Newbie / General discussionsReplies: 0Last Post: 7th Dec 2009, 14:56 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
Tsunami-Mpeg DVD Author Pro Transcoder Question
By RKelly in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 21:51
