I've never created menus for the homebrew DVDs I burn. And, I'd certainly not want to create full-motion menus or anything too fancy. But, I'd like to create a simple menu with single-photo background and simple push-buttons. And, at the fanciest, all I'd like to be able to do is perhaps add some background music to the menu.
So, I'd like to find out what menu creation software people would recommend for a beginner. Something simple and intuitive. Cheap would be a plus, too (grin).
The cheapest would be DVDAuthorGUI or GUIforDVDAuthor. Both are front ends to DVD Author, and it's all free
Payware, I would recommend Tmpgenc DVD Author
Both will do what you need.Read my blog here.
Originally Posted by guns1inger
Hmm. I actually have and use DVDAuthorGUI ... but didn't know you could "create" menus with it. I'll have to give it a second look. Thanks.
My bad - GuiforDVDAuthor creates menus. DVDAuthorGUI is for simple disc creation only.
Read my blog here.
Actually you can create motion menus with DVDAuthorGUI provided that you have Avisynth installed. They work pretty well!
GUIforDVDAuthor will create menus too I think and so will DVDStyler.
All are free and DVDAuthorGUI and DVDStyler are free software (Open Source).
Hope this helps,
RogerThere are many ways to measure success. You just have to find your own yardstick.
Software for MPEG to BD-R with simple/custom menus?
By daysaf00 in forum Authoring (Blu-ray)Replies: 9Last Post: 6th Jun 2012, 15:30 -
help required on making simple but 'deep' dvd menus
By lancealittle in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2010, 06:34 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Where can i download clean and simple dvd menus?
By Anonymous70 in forum Authoring (DVD)Replies: 0Last Post: 22nd Feb 2009, 07:17 -
Looking for a simple program to redo dvd menus for my home movies
By brycej817 in forum Authoring (DVD)Replies: 2Last Post: 24th Jan 2008, 14:31
