Well, I think that may say it all....I'm trying to replace the fist 30 seconds of a demuxed DVD with a sequence I've created as a TGA sequence. I absolutely need something frame accurate, as the audio will be added in a later step (in DVD Lab), and importantly, I'd really really rather NOT have to re-encode the mpeg part of the video, as it's already been through a recompress once before. The TGAs I assume I'll need to encode first before joining (planning to use Vegas). Although if there's something that'll add the image sequence directly to the m2v, that'd be ideal. I've seen a couple of freeware products mentioned (Mpg2Cut2, movie joiner) and a couple of relatively inexpensive others (various iterations of the Womble editors). Can anyone recommend any of these, or something else for this specific task?
Results 1 to 1 of 1
Tool to convert SWF (actionscript) to uncompressed AVI or image sequence?
By Koppel in forum Video ConversionReplies: 5Last Post: 1st Jul 2011, 13:23 -
Add a jpg in a mkv file at the begining
By flash_49 in forum EditingReplies: 5Last Post: 20th May 2010, 18:17 -
Adding an advert to the begining of a flim
By john59 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Dec 2009, 19:10 -
lossless editing MPEG-2 (*.mpg) with trimming and appending with preview?
By Andy Gone in forum EditingReplies: 8Last Post: 3rd Sep 2008, 06:49 -
Targa DP5100x
By garryb in forum DVD & Blu-ray PlayersReplies: 8Last Post: 15th Nov 2007, 12:55
