Ive installed the latest s2d
re-installed nero 7 - works fine on its own
movie process and title set work fine but...................
when it comes to burning the movie
s2d says finished with no problems but the disk has one small ring burnt into it as well with this log...............
11:00:09 DVD-Video files reallocation started
11:00:09 DVD-Video files reallocation completed (no file modified)
11:00:09 DVD-Video files sorted
11:00:11 Caching of files started
11:00:11 Caching of files completed
11:00:11 Burn process started at 2.4x (3,324 KB/s)
11:00:14 Unspecified Recorder Error
F: PIONEER DVD-RW DVR-107D
11:00:46 Generating DVD high compatibility borders
11:00:46 Unspecified Recorder Error
11:00:46 Could not perform end of Disc-at-once
11:00:46 Burn process failed at 2.4x (3,324 KB/s)
11:00:46 DVD NOT burned sucessfully
is something missing !!!!
as mentioned earlier no probs with coppy2dvd - just wont work with nero
What happens if you try NeroBurner on its own (outside of SVCD2DVD), to burn the same folder?
Then maybe the settings for the burner is wrong. Can you revist the settings and make sure the DVD drive is correct?
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 12:01 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 14:41 -
VOB2MPG 0 Vob Sets Problem - wont work
By meno in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Oct 2007, 21:36 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 19:04
