All right, I'll try to be as clear as possible with this. I've been doing this for months now but I've recently ran into a problem I can't find much information about.
Here's the problem: When I would load up an anime episode into VDubMod, and filtered subtitles into the video (hardcoding them), when I would replay the video, I would get these ugly chunks of blocks for split seconds in my video. I could also encode these avi files and make them m2v files, and I would still get the same result: blocks. I used Xvid to recompress the files and I read that using an older version of DivX (I had DivX6.1(?)...well, the newest version at the time) version 3.11, would fix this problem. 3.11 comes with the MPEG-4 Fast-Motion and MPEG-4 Low-Motion, but I don't know the differences. It did fix my problem.
My problem now is that when I add subitles and I fully process my video using 3.11, I (thankfully) don't get any more blocks, but I now get random jerky segments in my video. Example: when someones face will pan into the screen, it doesn't do it smoothly. There's a split second when I can see a jerk in the animation and I would like to know what is causing that. I was wondering if whoever made the files in the first place did a bad rip... or maybe I'm not as knowledgable as I think I am. Any information or advice would be awesome!
Thanks.
Okay, nevermind. I figured it out. It was in the actual frames of the movie, not the recompression. I was confused because my player wasn't showing the bad frames, but VDubMod was, so I just have to rid myself of the bad ones.
If any admins see this, feel free to delete this thread.
DivX3 to DivX5 or XviD?
By Ogilvy in forum Video ConversionReplies: 5Last Post: 13th Dec 2013, 18:24 -
DivX3 Problems
By Startropic1 in forum Video ConversionReplies: 4Last Post: 13th Jul 2010, 06:58 -
Is it possible to use xVid to decode Divx3?
By cheerful in forum Software PlayingReplies: 0Last Post: 10th Feb 2010, 12:35 -
Biostek XS-600 HD doesn't like divx3 what should i do?
By vivificus in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Jan 2008, 09:05 -
DivX3 to DivX6???
By npresto in forum Video ConversionReplies: 3Last Post: 28th May 2007, 18:49
