Hey guys, first post here.
I think this is the place for this question ?
I have a movie on my PC, but the sound is about 2 seconds slow. Like, a person's mouth moves, then the words come about 2 seconds later.
Is there any way i can change when the sound starts, or a program that can shift up the sound a few seconds earlier or something ?
To check it first to make sure it's a constant drift:
Use media player classic ( mpc ) under view,options, filters, audio switcher and adjust the audio time shift - or + value as needed. This is in milliseconds so 1000 = 1 second.
If it is constant and you want to fix the file then use virtualdubmod
Streams, stream lst, right click on audio track and click full processing mode, the interleave and adjust the audio skew correction by the needed amount. (You may also need to adjust compression if you don't want pcm audio. I can't recall if this step is needed or if it retains the original compression.)
When saving the file use directstream copy for the video and it should take less than 20 minutes. -
No, you just use MPC to determine the amount the sound is off.
You use VDubMod to make the change permanent. Hit "No" if it asks you a question when you open the AVI. Except there's no need to reencode the audio. gll99 had it a little bit garbled. Just adjust the delay (called audio skew correction in VDubMod). Takes less then a minute usually to make the change and save. Make sure you set Video to DirectStreamCopy. -
@Slasher_101
manono is correct. I was working from memory.
In Vdubmod the time skew is in the interleaving menu option which is available in the directstream copy mode for the audio so there is no reason to turn on full processing mode for the audio. Since neither audio or video needs to be recompressed, the avi should be recreated in a minute or so depending on the length of the video.
MPC is only used to set the exact time you need until the video and audio are playing in synch. Make sure you play the video long enough to be sure it stays in synch. Once you know that then you can use vdubmod to make the change accordingly.
If the audio drifts at an uneven pace then the fix is more complicated. -
Thanks guys, it turns out only the sound was off in the beginning, and it got better later. So it would be a mission to fix it fully ^^
(now see my new question: https://forum.videohelp.com/viewtopic.php?t=299771 )
XD
subtitles timing
By teamo1976 in forum SubtitleReplies: 3Last Post: 21st Dec 2009, 15:58 -
All was well ...then whats the hell wrong with the sound
By qwerty00000 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 26th Sep 2009, 05:39 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05 -
Video has sound but no picture from encoded avi file. What's wrong?
By Ivor Bigone in forum Video ConversionReplies: 4Last Post: 30th Jun 2008, 10:01 -
Timing wrong on captured video.
By Jack_Dante in forum Capturing and VCRReplies: 1Last Post: 17th Jan 2008, 09:20
