    May 2001
    Denmark
    Hey all,
    I wonder if there is an easy way to add both a small Intro and then Logo to my MPEG1, all during the asme encoding ?!?
    I have seen posts about multible files thru Frame Serving, but did not find any word on how to do it. It seems like I can only load 1 file in the Frame Server and when that is completed, TMPGEnc will also stop and not let you resume encoding.
    Any help on this is welcome
    Regards,
    John Brondum
  2. Use VirtualDub.(www.virtualdub.org)
    You can load your Intro clip as the first file and append the main file.One hitch though - suitable for AVI files - same parameters.
    Or use Avisynth. (www.videotools.net)
    To add a Logo, you can use VirtualDub, with its logo filter.
    Follow the instructions that come with the filter.
    May 2001
    Denmark
    Dinesh,
    ...so it's only possible with AVI files ?!
    I have been using VirtualDub for Logo and Frame Serving, but can't append/que a second file - that option is just grey.
    I'll take a look at that other program you mention and see if that works better for me.
    Regards,
    John Brondum
