I just got a Pioneer 530 and I can't format (initialise) +RWs in Video Mode or VR Mode :
Cannot make this setting with the currently loaded disc type or setting.
Also I have recorded in SP and XP and both give the same video bitrate (9500kbs) so I'm confused, the difference seems negligeble?!?!?
Results 1 to 17 of 17
To be "safe" always use DVD Video mode instead of VR mode.
The AVERAGE bitrate used for XP and SP are very different however both will occassionally "peak" very high such as 9500kbps. Play back a recording made at XP and then another at SP and use the remote function called DISPLAY which will put the bitrate currently being used on the screen. You will see that the XP recording will stay very high for most of the playing time where as the SP recording will be up and down and will only occassionally peak very high.
Don't feel bad about the lack of DVD+R recording. I have the Pioneer DVR-531H-s (which is very nearly similiar to your model) and it truely is one of the better DVD recorders out there.
- John "FulciLives" Coleman -
Well that is why one should always do research before buying anything.
Had you done the proper research you would have found out (rather easily actually) that the Pioneer DVD recorders do not suppor any of the DVD+R formats.
If you are annoyed by this then it is not Pioneer's fault ... it's your fault.
The good news I suppose is that since the Pioneer has a built-in HDD you really only need a couple or so DVD-RW discs. I bought a 5-pack for under $10.00 US Dollars. I use DVD-RW discs because I like to record programs to that type of disc so I can rip it to my computer and create a custom made DVD-R using my computer burner as I can use my choice of DVD Authoring software to make a nice custom menu etc.
Since I only use DVD-RW to "transfer" from the Pioneer to my computer I do not need all that many. Having a built-in HDD of course helps since recordings can be "stored" there instead of having to store them on a disc ala a DVD recorder without a built-in HDD.
Another solution ... copy to a DVD-RW then rip it to your computer with DVD Decrypter using the ISO READ MODE then burn it to a DVD+RW using DVD Decrypter in ISO WRITE MODE. In fact this might come in handy if the HDD is filling up and you only want to buy a couple of DVD-RW discs.
I have a Pioneer 420 and no matter what setting I use to record, the bitrate shows up as 9500 when I load the file into various programs on the computer.
There have been times where my HDD has been almost completely full and there have been times when it was under 50% full. Ever since I first started using it I never go much below 50% full since I am always recording something from cable TV it seems LOL
So the good news is that so far I've yet to have any issues with corrupted recordings etc.
I have tried to OPTIMISE the HDD a few times but it never works LOL
It will "start" to do it and say something like it will take 181 minutes or something like that (that was the most recent figure I guess it depends on how much is currently on the HDD) but then it just turns itself off after a minute or two.
I have no idea why.
I've heard other people say the same thing has happened to them.
Since I don't seem to have any problems with any of my recordings I'm just not going to worry about it.
I must say I'm disappointed with the record quality, my Philips DVDR70 gave better results in high quality mode. There's minor pixilation on bright images, I've tweaked the settings but it hasn't made a great deal of difference.
Well the Pioneer DVR-531H-s has two black level settings so I would assume your model is the same.
For Japanese NTSC and for PAL you want to set it for 0.0 IRE BLACK
For all other forms of NTSC other than Japanese you want to set it for 7.5 IRE BLACK
I'm talking about the input here of course.
So unless you have a steller DVD player sometimes it is better to leave the player in interlaced mode and let the TV handle the 3:2 pulldown etc. as a quality HDTV set may beat the DVD player (unless again you have something really steller in quality).
Hard Drive upgrade for Pioneer DVR-530/630H
By Hkan in forum DVD & Blu-ray RecordersReplies: 55Last Post: 22nd Aug 2012, 01:07 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 16:39 -
My Pioneer DVR-533H-S won't record DVDs or finalize them!
By superman123x in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st Jul 2008, 17:22 -
What's the difference in quality between SP & LP modes in MiniDV??
By navi310 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 27th Jun 2007, 11:09 -
Pioneer DVR-531 TVGOS menu won't even come up anymore/can't manual record
By ibhay in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Jun 2007, 18:34
