When I look at the reference of an app, for instance, D2MP, I read it needs avisynth, besweet, etc. so I know it wont install these.
When I look at other apps, such as alltoavi, there is nothing said, so I ask myself if it will install a lot of codecs (that probably already are in my computer) to support all the features, and at the end I will get a messy thing.
Is there a way to know what exactly is installing into your system any app before actually installing it?
Thanks![]()
First off, I'd highly recommend setting a restore point (if using xp) and having a fresh backup of your system. Not that I've used or installed these problems, but I have lit up a few systems installing CodeC packs.
The following is for Win2000, but it may give you a better idea as to what to look for -
http://www.microsoft.com/windows2000/techinfo/reskit/tools/existing/instaler-o.asp
Sabrowww.sabronet.com - It's all you need...to know -
no, but hopefully does it come with a good uninstall that can remove all the crap...
Also you may want to look at http://www.devhood.com/Tools/tool_details.aspx?tool_id=432
Haven't used this or Microsoft's so use due caution, but hopefully it helps.
->Baldrick - If 99% of the apps uninstall's actually did what they are supposted to do, I'd prolly have about...well 99% more free space hehwww.sabronet.com - It's all you need...to know -
Thanks Sabro and Baldrick. I usually set a restoration point before installing. But, as much for this, as the software you linked (Sabro), I'm not very confident to any of them.
I mean, in my deep, I believe that things wont be the same than before. And about uninstaller utilities, lol, one must be very hopefully :P
I think that this is the reason why two computers that appear to have the same things installed, don't work the same. Once I had a computer in wich Tmpgenc dealt with VBR audio with no problem, and I never knew how I did itto work this way.
ugh!!
Installing CPU
By HotDamn! in forum ComputerReplies: 11Last Post: 11th Dec 2009, 00:40 -
installing win95 on hd that has xp
By mac71671 in forum ComputerReplies: 15Last Post: 18th Feb 2009, 20:08 -
Installing XP on a used PC
By CSULB71 in forum ComputerReplies: 24Last Post: 21st Nov 2008, 11:05 -
installing
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Mar 2008, 07:13 -
I have to ask again, trying to installing Win98.
By capman21 in forum ComputerReplies: 45Last Post: 23rd Jun 2007, 12:38
