    Apr 2006
    When you watch any commercial DVD you always see the FBI warning start up first. How can I go about adding the warning to my dvd. I'm using nero express...I have 6 videos. 1 is for the FBI warning animation then it should go to a menu.
    The menu will have 5 videos that can be chosen from.
    I'm using nero7 express, but I can purchase any program that can setup an autorun feature. I want to add previews before they get to the actual video's menu. Suggestions are greatly appreciated.
    -R
    Apr 2006
    What can I do to make it so when I put my DVD into the DVD player it takes me to a preview rather than straight to the menu.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The feature you are looking for is usually called First Play. You set an item to be the First Play item, and it will load as soon as the disc starts. I don't know if Nero can do this, but most real authoring apps can - TDA, DVD Lab Pro, DVD WorkShop. I suspect even DVD Author can do this.
    Read my blog here.
