Subject sort of says it all. For literally years now, high-definition programming has been acquirable in vast quantities. I have never seen the material presented in any other format than .TS, with the lone exception of a specimen of WM9 video. There is the occasional happy event when the .TS file is one single, giant file clocking in at over 10 gigabytes. This is indeed happy because it is such files that I am able to successfully play from beginning to end without any real complications.
But most of the time, what one instead discovers is that the material has been split up into segments of 100 megabytes each. And I have never found a piece of software - not even the great Zoom Player Pro - which can play these files in batch, seamlessly, without pauses between each.
It really seems to me that since HDTV content is almost entirely available only as multiple .TS files, there really ought to be many solutions, including the most obvious, ie a piece of software that *gasp* can actually play them seamlessly without any sort of preparatory steps. There pretty much has to be. That's why I'm asking. Meanwhile, a couple of things I have tried:
1: Copying the files together manually. This actually seems to work at first. When I copy two files together, the result plays fine. It's when I copy the whole thing together that suddenly no player can do anything with the result.
2: Combining the files using "HDTV to MPEG2". This purports to be a piece of software specifically designed to convert the .TS files into an MPEG2 file, or files. The documentation does not mention whether or not this happens to include, as part of the package, a redundant re-encoding, but I assume not. Nonetheless, I have never actually had this piece of software spit out something that any player has been able to do anything at all with. And even if it did suddenly start working as advertised, this is a step which I would like to believe is automatically redundant; there really has to be a player that doesn't require one to combine thirteen gigabytes worth of files into one.
Anyway, thanks in advance for whatever turns out to be the definitive answer.
Closed Thread
Results 1 to 12 of 12
Try using VLC Media Player. Ive found that it can play the file you suggested in 1.
" Copying the files together manually. " always works for me... Try TSJoiner (at the bottom of http://www.svcd2dvd.com) which puts a GUI around the copy /b command.
hdtv2mpeg2 works fine here, to copy to one single ts and it works in all my mpeg2 players with the hdtv pump filter.
vlc media player can play splitted ts but it's a pause between each.
if you choose the output type as ts, not mpeg in hdtvtompeg2 it will reassemble all those 100mb parts back into one ts.
Well, I can only reiterate that I've tried the two file-joining options and have met with essentially zero success.
Copying (/b) the files together seems to stop working correctly if I try to splice more than the first couple together. I have no explanation. None of my plethora of media players are able to recognize the resultant file. This has happened with over 12 different movies.
I have also given "HDTV to MPEG2" a few tries with different movies. Each time, what it has produced has been a file which really confuses my media players. What most of them do is "play" the first ~5 seconds of the video (without successfully showing any actual video - just a black screen) and then stop itself like I'd clicked the stop button. Attempts to seek directly to the middle of the video cause the players to simply not play anything nor even attempt to.
It totally baffles me how these options have been used with apparent success by other people when every single time I have used them, the results have simply not worked.
Yes, I do present the files in their sequential order. In addition to using a batch command like "copy /b *.ts file.ts" I have painstakingly specified each file, as in "copy /b file0001.ts+file0002.ts+file0003.ts" etc. Same unusable results. According to other forums I have read, people are in great disagreement over whether this function should even work, and indeed, my own results suggest that they don't, or are highly unreliable.
Of course if somebody ever managed to develop a player that could properly handle multiple .TS files, this facet of the discussion would be mercifully irrelevant.
No dice. I can make a 1GB chunk that plays fine. But once I've made the whole file, no media player likes it. Tried with three different movies now.
This inexplicable lack of results is the reason why I would strongly prefer a piece of software that doesn't require this sort of headache to be undertaken. Why do people post 100MB .TS files in the first place, if there's nothing out there that can even do anything (satisfactory) with those files without pre-processing?
In an effort to nail down just what the heck is going on with this TS file madness, I have done a series of combines with HDTVtoMPEG2 using different movies originally separated into 100MB chunks.
What I've determined is that there are some TS chunks which no media player likes to play. They are not common. Parity checks confirm that the files are not corrupt. If any of them are passed through HDTVtoMPEG2 to create a larger file, the entire file cannot be played in any media player. However, HDTVtoMPEG2 itself has no trouble at all playing or processing the files, so they are evidently perfectly valid TS video.
Does anyone have a guess as to what is engendering this phenomenon, and why no media player likes these TS files when HDTVtoMPEG2 has no difficulties?
By what mechanism are these files acquired?
Your HD is not fat32 by any chance?
Sounds like there is indeed some sort of corruption, as often happens in analog captures. SFAIK this is not supposed to occur in digital captures, at least not in the same way. Have you tried any repair options, Restream, PVAStrumento, anything similar?
Is there any pattern to these corrupt segments? Same time frame in video, same segment number, immediately before or after the hour, etc?
I have just now tried out the two applications you suggested. PVAStrumento did not like the files at all, whether I fed it a "corrupt" specimen or a "non-corrupt" one. The problem seemed to be that it was expecting valid DVD MPEG2. Restream seems to be a reencoding application. I fed it both types of TS file and it spat out carbon copies, and the playback results of these copies were, predictably, identical to those of the original files. Restream seemed not to detect anything corrupt in any of the files.
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 11:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
No audio on HDTV playback
By BA TRAN in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 12th Oct 2007, 16:56 -
Multiple HDTV TS files to DVD with SVCD2DVD HELP
By ndoggac in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 18th Jun 2007, 12:21
