hi admin,
i desperately need ur help or anybodys help!
i want a make a dvd with atleast 4 (or 6 if possible) movies of 700 MB each playable on a dvd player with a nice menu,on which a background music and video are running with effects and running video in thumbnails.....etc.etc....i want to make this as easily as working with frontpge or word or paint.
Could u recommend the best software for this?
Thanx
Closed Thread
What you are asking is not possible.
Stop it now.
why is it not possible i have bought 5 in 1 movies dvd of course all were cam recorded....but the menu was nice and the dvd had 5 MOVIES!!!!
Maybe if each movie is 30 minutes or less you might fit 5 movies on a single DVD otherwise ... forget about it.
no....the movies were full
narnia
king kong
just friends
wallace gromit
zathura
what do u hav to say abt that
Originally Posted by amjad_z4
Two I am sure they looked like SHIT and if YOU thought they looked good then YOU need glasses OR you have a very small TV and/or a combination.
Some of those low budget multi-movie packs use VCD resolution in order to fit4 or 5 70 - 80 minute movies onto a disc. The quality is low, the sources usually VHS tape (sometimes not first generation), and even in the $2.99 bin they are a rip-off.
As an exercise, do the following. Calculate the total running time for all the movies put together. Put this running time ito a bitrate calculator and work out the bitrate required to make them all fit on a single disc. Report back with the numbers and we'll tell you what resolution you would have to go down to to have half a hope of making it fit.Read my blog here.
Making a LP DVD
By zarnic in forum Authoring (DVD)Replies: 13Last Post: 11th May 2011, 07:47 -
making DVD
By narcissus in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 00:18 -
making DVD
By narcissus in forum Authoring (VCD/SVCD)Replies: 2Last Post: 14th Jul 2008, 19:22 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Making a DVD
By Lord Balthazar in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2007, 08:10
