Page 3 of 3
FirstFirst 1 2 3
Results 61 to 63 of 63
  1. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    now you're setting specifics. If the point stated were in the same room as you, you'd have taken the long way around the globe to get to it. :/
  2. When there's a ~60 percent difference in encoding time, on the same computer, simply from changing one TMPGEnc setting that isn't controlled by the MCF file, the results are nearly useless.
    https://forum.videohelp.com/viewtopic.php?p=1479223#1479223
  3. We'd need to work out the bugs, but it's possible, isn't it?
