can season episodes be split with shrink
i checked the guides but it does not say.
also why not use a dl ?
Reason for this is not quite happy with quality of compression
THX
You can split it with Shrink, but you will lose the menus if you use re-author mode. Your other choice is to replace the episodes you dont want with still images, but if you are going to use that route, there are better tools available, including vobblanker or titlesetblanker.
Why not use a DL ? Is that a rhetorical question ?Read my blog here.
I have been unsure about the high rate of coaster from dl.
I do want to keep the menues on both DVDs after the split. I do have vob blanker. Does that help with this?
Thanks -
Some reading to get you started
https://www.videohelp.com/guides.php?guideid=750#750Read my blog here.
I appreciate the help. I just finished reading the guide you linked.
I guess some time will have to be spent to learn this.
Dosnt dvd fab have a simpler wizard type program for $$$.
I checked prices on DL. $3.00 each. I guess that cuts that out, unless it is a movie. but foe season type shows changing dvds is expected. -
There are a few payware programs to do this - DVD Fab, DVD Remake Pro etc. DVD Remake Pro is probably the best of the payware methods. Have a look at this tutorial for using it to split an episodic disc, preserve the menus, and remove the buttons that no longer work http://www.deano.dsl.pipex.com/dvdremake/guides/episodesplit.htm
Read my blog here.
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 12:40 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
DVD shrink missing episodes
By CraftCove in forum DVD RippingReplies: 3Last Post: 3rd Dec 2008, 00:53 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 16:09 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 01:23
