Having major problems, with recorder. I get write fail errors when recording a show and now the format option does not complete. If I replace the burner with one off the shelf will this cause me problems or do I need a special burner from daytek for this unit. Thanks -garman
If you don't get any answers, pull the case off and see if it is a regular DVD burner, with the proper 40 pin IDE connectors and a Molex power connector. If not, it's doubtful.
So if it's a standard connector I should be able to use any brand name in it's place? The other problem it is a single layer +R +RW burner. can I use a multi-format (+ -) drive. Thanks -garmanOriginally Posted by redwudz
There may be a lot of 'ifs' involved. If the connectors fit and a different drive will fit, and if the DVD recorder can recognize the drive, and operate it....... I wouldn't buy a burner for that purpose just yet, but you might try one in there and see if it will work. The DL format probably won't work, along with + or - selection. A lot would depend on the recorder and how it operates the drive.
That appears to be a rebadged Lite-on DVD recorder. See here for some info:
http://club.cdfreaks.com/showthread.php?t=135294
It seems they recommend using a Lite-on burner for replacements in the regular Lite-on recorders. Maybe some more info for replacing a drive in the Lite-on Recorder forum: http://club.cdfreaks.com/showthread.php?t=153421
And you might find more if you dig around there a little.
I don't want to get your hopes up too much, though.
Fixing/Replacing DVD-burner (Pioneer 630-H) -how?
By tigrr in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Feb 2011, 17:20 -
replacing a DVD burner on my polaroid 2001
By majel in forum DVD & Blu-ray RecordersReplies: 0Last Post: 9th Aug 2010, 17:04 -
Daytek 950-S burner replacement request
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Jul 2008, 10:24 -
Daytek DVDR-P30 what brand DVD+R do you use? my HP 16x DVD+R don't work
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Oct 2007, 23:22 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 16:43
