Hi,
I have a movie which is made up of 2 mkv files, each of these files has 2 audio tracks and 1 set of subtitles. What I want to do is put the movie onto a dvd (or dvds) without using any compression method and without removing and audio tracks, I only have single layer DVDs but I don’t mind using 2 of them.
I have already looked through quite alot of guides on this site and others and the only way I have found to keep the audio tracks and subtitles is by using avi2dvd. I attempted encoding with avi2dvd using the HCEnc encoder (a website said this was best encoder to use), however once running the program said it would take 19 hours which I thought was a bit excessive for a 1 hour 30 min movie.
Can anyone recommend a method to make these mkv files playable on a dvd player and keeping the audio tracks and subtitles?
Any help is appreciated
Guts
Doesn't sound excessive if you have a slow PC and is doing max options like Trellis, 2-pass, max quality, etc. Besides, it's just an estimate and subject to change. Takes about 3-5 hours to do a 700 MB AVI on my 2.67 GHz P4.
Hi,
Okay I have accepted that it will take a long time to encode these mkv files, but I have another problem. There is letterboxing on these mkv videos, the only way I know to fix letterboxing is with virtualdubmod but this will not accept mkv files. Therefore all I can think of is encoding the files into mpeg-2 with avi2dvd and then use virtualdubmod to crop the video and remove the letterboxing.
The question I have is whether this is a good idea or not? The files I will be trying to use with virtualdubmod are .VOB, can I save to this type of file after using virtualdubmod or not?
Also I am aware these are encoders which can remove letterboxing but I want to use avi2dvd so I can keep the two audio tracks and subtitles.
Guts
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
plz help my dvd audio is always cracking in my home theater system.
By rex2745 in forum Newbie / General discussionsReplies: 11Last Post: 24th Jul 2007, 06:10
