I want to create a dvd from a dv tape that i can set to have chapters every 3 minutes but doesnt then force me to have a menu.
Reason is that i want to be able to skip forward without using the fast forward button.
Does anyone know of a program that can do this?
Results 1 to 9 of 9
TMPGEnc DVD Author will do it. You'll have to convert the video first though.
Free 30 day full function trial. -
ConvertXToDVD from VSO will do this...it will let you set chapters and whatever minutes you wish, without or with a menu. Will also burn the dvd for you too. Good software.
I'll give it a go, currently downloading it.Originally Posted by lafjax
Whats the quality like? Is it as good as any other dvd authoring program -
Not an authoring program, it's an all-in-one which converts and authors.Originally Posted by bohboh
Not having used it I can only pass on that it's better than some but not as good as the best programs. Generally all-in-ones are avoided by those that want the best quality."Art is making something out of nothing and selling it." - Frank Zappa -
Strange, I did one with no problems. (or at least the image on HD gave me no problems. )Originally Posted by bohboh
Excellent.
This applies to my situation as well. I'm using Pinnalcle Studio V8.
Does anyone know of a way to set it so that you can skip forward.
Otherwise you have to watch the entire DVD in order to see the last quarter or so.
ThanksBarbara
Looking For Software to Create Menu- w/ Fade Transitions Between Chapters
By restmin in forum Authoring (DVD)Replies: 2Last Post: 13th Apr 2011, 17:36 -
Unable to create chapters while converting from AVI to DVD using DVDAuthor.
By sumit_pankaj in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2009, 02:40 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 17:26 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
