Hi,
I'm using AviMux-GUI for joining AVIs, but I wonder if there is another free tool (stable) that is better than this tool to join avis
is there any ?
if not, what is the better whay to join AVIs ?
thanks
Results 1 to 9 of 9
I use VirtualDub to append one AVI segment onto another, especially when movies have been split into 2 or more AVI chunks.
Best Wishes!
TTWC"I've got a present for ya!" - TTWC -
I use file saw works good so far no problems its free do a google search for file saw .
From the File Saw home page:
It just blindly concatenates (and splits) files. Inly time it's work with AVI is if you first used File Saw to split one AVI into smaller pieces, and then join them back again. Full separate AVI's have headers and indexes and stuff, so can't be just glued together - a new AVI has to be created, and VirtualDub is the tool to use. The restriction is that all parts have to share all properties - frame size, codecs, bit rates & c. Not a shortcoming of VirtualDub - it's just the way it is.# Notes: This product can only join pieces of one single original file. It is not a movie editor to create one long file from separate pieces nor can it create smaller viewable pieces from one long media file. This applications is for file storage and transfer only.
/Mats -
yeah, that's why I don't use VirtualDub because o this limitations. Frame Sizes must be equal ? didn't know that, I thought was only codecs and frame rates
I think there is no better solution for this in order to convert 2 AVIs to DVD -
If you were going to convert them to DVD, don't join them. Encode them separately to DVD compliant MPEG-2 and let the authoring program do the 'joining'. You will avoid a lot of sync problems that way.
... let the authoring program do the 'joining'
thanks for your reply. But How can that be done with Sourceforge FREE DVDAuthor tools ?
I encode video and audio separately and then muxed it together using DVDauthor's MPLEX.EXE tool. Then I make a XML file and DVDAuthor the muxed MPEG-2 file
Where and how to include or join the other MPEG-2 file ?
can you give me some clues ?
thank you very much -
dvdauthorgui or GUI for dvdauthor perhaps ?
If in doubt, Google it. -
You didn't understand me - it's not because of a shortcoming in VirtualDub. You can't properly join 2 AVIs with different properties, regardless of tool. Only way is to reencode one or the other piece (or both) to make them match.Originally Posted by Delta2
/Mats
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 9th May 2010, 00:16 -
? Shrinking Multiple AVIs to Target Total-Size Then Joining to Originals
By Synetech in forum EditingReplies: 2Last Post: 4th Apr 2008, 22:14 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 15:32 -
Trouble joining two mp4s (or two avis)
By nosillacast in forum EditingReplies: 2Last Post: 27th Sep 2007, 10:30 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 11:06
