Hello,
I would like to put a large .avi with a big bit rate (10M) on a CD. I know this does not play back from the CD drive when you click on the file - It is too jerky. Is there a way to set it up so that when someone clicks on the file - It buffers until it can play back smoothly?
Thank You for the help
I recall a software program that did something like this, CD Lightning or something like that, it was basically a caching program for the CD. Would pre-copy approx 100 MB for each CD, I do not know if this cache was dynamic, or simply a directory structure and file list, which would not help you.
With HD space what it is today, best alternate is copy it to a temp directory and play from there. This could be automated in software. -
Thank you for the response. Would it be posible to do this if I knew they would be using WMP9?
Thank You
DVD Playback problem after 2nd time
By cschoon in forum Authoring (DVD)Replies: 0Last Post: 19th Jan 2009, 09:33 -
How can I fix the playback time of a title when replace the VOB?
By Massa in forum Authoring (DVD)Replies: 5Last Post: 17th Jan 2009, 14:25 -
Correcting actual playback time of .vob files
By sooojaded in forum EditingReplies: 4Last Post: 7th Sep 2008, 03:30 -
Fixing Time Playback Issue in MPEG2
By NightFire in forum Newbie / General discussionsReplies: 3Last Post: 10th Feb 2008, 00:52 -
Disable the playback buffer for quick interaction.
By youblokle in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2007, 18:16
