Like the topic says.
When I record, the bottom part (about 1/3) of the screen is green, and the picture has moved upwards (see attached picture... it should be widescreen). It's also something wrong when viewing as well, but i dont see the green field than.
Just bought the capture card. Not sure if I'm doing anything wrong.
My capture card is a Hauppauge ImpactVCB 64405 Rev. C1 .
I'm using a software called WinTV2000 to capture the video.
I'm capturing in PAL N (pal system).
Any other recommended capturing programs? (under $100, please)
Results 1 to 1 of 1
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 18:19 -
green line at bottom of video window
By miniboss91 in forum Video ConversionReplies: 3Last Post: 11th Jan 2010, 20:51 -
There is a narrow line at the bottom of my screen.....
By gom in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 11:16 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 14:39 -
Subs cover-up bottom of screen
By ProudAnselmo in forum SubtitleReplies: 3Last Post: 10th Jun 2007, 01:13
