Hi,
I wonder if anyone can help me. I am using Pinnacle Studio 9.3 and when capturing - the preview pic is very bright. I have tried altering all the settings, but nothing helps. I decided to run 'Amcap' to see if the fault was the same. When I went into the device menu I noticed that there were two composite and two svideo options. When I select the first composite option the pic is very bright, when I select the second option the pic is normal. I have tried to uninstall some video codecs, but when I restart my pc, windows xp reinstalls the codecs. Has anyone any ideas for this. Last thing I want to do is flatten my system. My original capture card was a winfast vc100, but this died on me. My current capture card is a pinnacle dazzle video collector.
Many thanks
Iain
Results 1 to 1 of 1
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 15:04 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 21:19
