I have been using Tmpegenc for awhile now to convert my avi. files into mpg. files for VCD. I just got the newest version of Tmpegenc and now when I load any avi. file, even ones that I have encoded before, the audio will not show up in the audio source box. I have no idea whats going on and would like some answers for this problem. I have also tried the method of using virtuadub for the audio, but when I try to load the audio I have extracted into Tmpegenc a box will pop up and say: "______.wav file is unsupported, or cannot be read". Thanks for your help!
Ikari-kun
It seems that you have not installed the VFAPI plugin for TMPGEnc. More information on: TMPGEnc.com
The Dutchman -
No, I have had the VFAPI plugin, and it still wont read the audio on any video source, even the most recent version.
Do you have the plugin in the same folder as TMPGEnc? Did you double click on it?
The Dutchman
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 15:09 -
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 10:14 -
Remove subtitles from MKV when converting with TMPEGEnc
By ikarishinji41 in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 10:21 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 14:39 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 00:38
