I was copying movies, and one of the movies says that it is too large, just by a bit, but it won't burn onto a dvd. I have dvd shrink and decryter, and use nero for burning. I use the dvd 5's and I'm not sure how to shrink it so that it will work. Any help is appreciated!
yeah, I kind of figured that, but what do you change in dvd shrink to make the file smaller? can you give me steps? I'm realy not sure about much of this stuff.
The first thing I do is dump the extra subtitles and languages that I don't use. Then I save only the AC3 5.1 audio. The other audio formats you don't really need. You gain a little there. Next is the extras. Using analysis helps make the most use of what you have left.
The problem is that if it's really too large for Shrink to make it fit with the default settings and you Shrink it even smaller, the quality will quickly begin to suffer. If you don't care, you can run it through Shrink a second time. That's the easiest solution.
Better is to split it to two disks or use a program like DVD Rebuilder to re-encode it. Shrink just transcodes, which is another way a saying it just throws away parts of the video that it thinks you won't miss. -
i do movie only backups , cut out the credits if need be.
lots of good guides to the left
or here www.dvdshrink.info
large mp4 file to dvd
By GP_Wouter in forum Video ConversionReplies: 6Last Post: 3rd Nov 2010, 15:22 -
How to shrink a large .M2TS file?
By neworldman in forum Blu-ray RippingReplies: 2Last Post: 12th Jun 2010, 09:16 -
Burning large file onto CD or DVD
By Tom in HD in forum MacReplies: 3Last Post: 2nd Jan 2009, 16:06 -
dvd shrink: single large file or multiple small files
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 22:43 -
DVD feature shorter than the original file
By oresztesz in forum Authoring (DVD)Replies: 0Last Post: 20th Feb 2008, 08:27
