Is there a proggy to convert from WMA to WAV, if so how's quailityof files after?
Results 1 to 12 of 12
Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live!
here's another one that will do it and it's free.
http://www.dbpoweramp.com/dmc.htm
that is as long as it's not drm protected. then nothing will digitally convert it.--
very well, thanx!
Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live! -
Try MediaCoder it's fairly bulky over 12mb but will convert wma to wav not a problem,and it's bloody quick.1 song took 2 seconds!
Originally Posted by aedipuss
Just my luck the file is drm protected, any leads to get around this?Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live! -
only if you own a license for it. if you can play it, programs can capture the analog and convert back to digital. not very elegant but that's about it.
Any programs in mind to use 4 capture?Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live! -
Personally I convert with SPAM Besides converting between different audio formats it removes frm-protection if u download music on-line (Napster, Itunes etc.)Originally Posted by yoda313
You are in breach of the forum rules and are being banned for spamming.
/ Moderator mats.hogberg -
If all you want to do is convert, then there is a nice program from Acoustica that does that, only that and does it very well. Check it out at http://www.acoustica.com/mp3%2Dwav%2Dconverter/. The nice thing about this program is that you go to the folder where your .wma files are, right-click the file(s) and select convert from the pop-up menu and DONE! Great quality. Other than to personalize your settings, you don't even go into the program to do it.
-Brett -
None of these programs listed worked for me.
It probably didn't work because of DRM. The DRM should allow you to burn an audio CD copy of the song(s). I have paid to download a few official DRM-ed WMA files of Paul McCartney songs and Windows Media Player allowed me to burn an audio CD of them. Once you have an audio CD, simply rip it to WAV format using MusicMatch or any similar program. Yes, this requires an intermediate step of making an audio CD, but it should at least work.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
WMA-2.WMA-3 files conversion
By sumeshkri in forum Video ConversionReplies: 3Last Post: 27th Sep 2008, 19:52
