Every time I try to burn a particular project in DVD Workshop 2, I cannot complete the burn.
I always receive a message that reads "unspecified error; error code 800413a8."
Any suggestions as to what I should do to resolve this issue?
Thanks in advance for your replies.
I had the same problem when working on a PAL-->NTSC project a few weeks ago...and could not find a fix, unfortunately. I had to use a different authoring program. From my research, it appears DVDWS2 has issues reading converted framerates.......... ??? Are you by chance trying to author converted PAL to NTSC or NTSC to PAL?
If you're importing already muxed video/audio, try demuxing in a different program (i.e., TMPGEnc) and import elementary streams into WS2.. or conversely, if you already have demuxed streams, try muxing in another program, then importing remuxed stream into WS2. I gave up and used another authoring app. -
OEM version.. no support. But there have been reported inquiries to Ulead without response (or atleast a public/reported one).
I am using the NTSC format.
I tried to contact Ulead customer support about 2 days ago and they have not contacted me yet. -
If/When Ulead responds, it would be greatly appreciated if you could relay what they said, please.. Thanks and good luck.
Ok, Ulead finally contacted me and this is their exact e-mail:
Kindly try the following to refresh and update the program files.
1) Uninstall Ulead DVD Workshop 2 from control panel Add/Remove programs.
2) Delete this folder "C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead DVD Workshop\2.0" (Please set "Show hidden files and folders" in folder option in Control Panel)
3) Delete this folder "C:\Documents and Settings\[YOUR USERNAME]\Application Data\Ulead Systems\Ulead DVD Workshop\2.0"
4) Delete this folder "C:\Program Files\Ulead Systems\Ulead DVD Workshop 2"
5) Reinstall the program again.
Please install the 2.232 patch from this link:
http://www.ulead.com/tech/dws/dws_ftp.htm -
Thank you much, Jesse217--much appreciated. This problem only occurs on my PAL<-->NTSC conversions. Will give it a try.
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
DVD Workshop 2 audio problem
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Feb 2008, 20:49 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 10:16
