Results 1 to 10 of 10
I tried doing that, but it wouldn't work, it said that it was unsupported format.
I did however use ffmpegX, and encoded both bin's. And now Toast accepted them. I put the second part right after the first part, so it will probably jump when they meet, but oh well. we'll see.
But, I thought Toast would do it all too, but it didn't, I tried to drag it into the toast window, and it wouldn't work.
thanks -
Well, I want this burned to DVD. So hopefully it will burn to DVD.
the whole bin/cue thing is new to me. I am not sure.
But I do appreciate all the help.
Also, CASE: When I am in the bin/cue copy mode, can I drag a .bin file in? Or does it have to be .cue?
Thanks -
I've only seen bin/cue CD-ROM disc images. Not sure if the file format supports DVD. If the bin/cue files are meant for CD-DA/VCD/SVCD, then it won't work for sure, and Toast will tell you so as it attempts to burn.Originally Posted by AntnyMD
I suggest ±RW, heh.Originally Posted by veganjustice
It's a disc image, no way for others to tell what's in it, unless you tell us.Originally Posted by veganjustice
If it is VCD or SVCD, then I would extract the MPEG stream(s) out of it and go from there. For most players, you'll need to convert first for (S)VCD to DVD.
Read the friendly manual. Page 95 of the Getting Started Guide PDF.Originally Posted by veganjustice -
From time to time I searched for a solution too. Now I found Gumby at http://www.versiontracker.com/dyn/moreinfo/macosx/22271
It converts the bin-file which usually has some 800MB into a perfect mpg-file with some 795MB. Fast and clean.
With this mpg-file it is no problem to continue with ffmpegX or -- if there are other applications -- with other applications. But I use ffmpegX.
Note: I had a problem opening the sit-file ( Gumby_50C.sit ) after downloading. There appeared only an "empty" folder ( Gumby 50c ). One minute later I discovered that the "empty" folder had a file size of 8.2MB, so I added the ending .app to it ( Gumby 50c.app ) and -- voila -- it was what it should be: an application. (But possibly maybe this error appeared only on my machine.) -
Awesome. Thank you for that. I have had tha app forever, and never realized that.
Thanks!
And thanks to everyone else for the help.
veganjustice
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
