Results 1 to 10 of 10
    Dec 2005
    Turkey
    I'm new here. I guess I have an unusual problem with SVCD2DVD.
    For some reason, I cannot use .avi files as assets. I do it by selecting add assets, I choose an avi file, try to drag and drop but it doesn't allow me to do this. I choose the file by double clicking, nothing happens. I've tried different avi files with different codecs without any success. I have no problems with mpg files.
    I have the latest registered version but I had the same problem with V 2.0. It doesn't give me any error messages so I don't have any logs. Am I doing something wrong with the settings?
  2. It shouldn't be a setting issue. Have you tried locating the .avi files in "my computer" and drag and drop them to the S2D assets window?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Dec 2005
    Turkey
    I've tried what you have suggested but it still won't add avi files. This is really strange.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you open the problematic file with Gspot and post the findings? Like:
    Dec 2005
    Turkey
    These are just two of the files I have. I have tried about 10 files, none of them worked.
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok. Can you use the makesample tool in the "Tools" folder under where you installed SVCD2DVD and send me (via email) a smallish sample of one of the avis? Can you make sure the sample exhibits the same behaviour?
    Dec 2005
    Turkey
    I've just sent you the sample file.
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Thanks. Got it. I will take a look in the morning.
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Works fine for me. Perhaps you have funnies in the path?: https://forum.videohelp.com/viewtopic.php?p=1504517
    Dec 2005
    Turkey
    The problem is solved. There was a character problem but a different one from the other post. The problem wasn't the path since I used mpg files with no problems from the same path. I renamed the extension from avi to AVI. This solved the problem! Still, it's weird it cannot recognize avi files with .avi extension. Probably something to do with the Windows Turkish version.
    Thank you for your help.
