    Jan 2006
    On 1 PC I installed latest SpoofStick version with everything appearing normally, but on a second PC the SpoofStick tool bar begins at the end of the tool bar beginning with the Internet Explorer 6 address window resulting in SpoofStick displaying only "Yo" and chopping off remainder of info that should show "You're on: Actual URL you're currently on." For example it would show "Your on: Google.com" if you're really on that web site. For any who may not know SpoofStick is a free download that alerts users of phising exploits. I've emailed queery to http://www.spoofstick.com/ where SpoofStick is available but have received no response for about a week now. Does anybody here know whether this is a SpoofStick problem or Internet Explorer 6 problem as well as any possible fix for the problem?
    Oct 2005
    666th portal
    right click in grey toolbar header. unlock it. click on tool you want to move and drag to where you want it. right click and lock.
    Jan 2006
    I had to place cursor where arrows point right and left to be able to drag and drop after unlock, but it worked once I did that. Thanks for the how to.
