  1. i have a satreceiver that i use to record some daily hows. I archive them now with autogk, that perfectly opens my .ts files. How can i get VirtualDub to open these files directly? Or is the only way to demux them and the recombine? which is a lot of work
    what do i need then to combine the m2v and mp2 file? VD doesn't recognize the mp2
    virtualdub doesn't support mpeg2. use virtualdubmod or virtualdubmpeg , if you can't open the ts directly try hdtvtompeg2 or frameserve from avisynth.
  3. i already tried demuxing the stuff, si get 2 files: the mpegs2 i can open with vdubmpeg, but how do i combine it with the audio file? mp2 is that one
  4. Member Soopafresh's Avatar
    Jan 2004
    Another option (if you have the room) is to convert the TS to regular MPEG2 with ProjectX
  5. Banned
    Freedonia
    Although it's not free, the Divx Converter at http://www.divx.com could not be simpler for doing this. It's biggest fault is that there is almost nothing you can configure on it, so you get very very little control over the final output. Dr. Divx (http://www.drdivx.com) is free and does give you all the control you need over the output, but it may choke and die for no reason on some video input files. It is not necessary to demux with either of these programs.
  6. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    I use virtualdub mpeg2 myself to open those files. Then I add some filters, like msu_deblocking, delogo / logoaway, static noise reduction, dynamic noise reduction, resizing, etc. Then, I frameserve and encode to whatever I wish or export to mpeg4
