Hey i just bought the new samsung 4692d flat panel lcd HDTV and want to hook this thing up to my PC. i went to go order a long VGA cable and noticed there was SVGA's. What is the difference between these two cables???? which one should i get for my HDTV????
Results 1 to 15 of 15
well the tv has a hdmi connection and my video card has DVI out. So i can get an adapter but i heard that there wont be much ofa difference than with vga and if i plugged it in the hdmi, it wouldnt be easy to set up wouldnt be plug n play
If it has a VGA input that is an analog RGB connection that will work with square pixel computer resolutions like 800x600, 1024x768.Originally Posted by mikej3131
The display card DVI-I connector has pins for analog VGA or digital DVI-D. DVI-D can be adapted for the HDMI connector with the right cable. HDTV resolutions are 480i/480p/720p and 1080i. Your set most closely matches 720p. -
[quote]If it has a VGA input that is an analog RGB connection that will work with square pixel computer resolutions like 800x600, 1024x768. [quote]
The manual on my tv says one of the display modes for the pc input(vga) is 1360x768. It says this is for VESA????
it says i can set this resolution in the display properties -
If your computer graphics card supports that resolution, yes
Many of the newer video cards do support widescreen resolutions like 1280x720, etc. -
Vesa resolutions including wide (square pixel)
http://www.gen-x-pc.com/lcd3.htm -
I wish they would stop using acronyms like VGA, XGA, SXGA, UXGA, WXGA, WSXGA, WUXGA7. Who can remember them all? Soon the acronyms will be longer than just stating the resolution!
so i have to get a xga cable to b able to set my resolution to 1366x768. What is all this saying? wil my svga b able to display widescreen
The VESA acronyms for resolution really have nothing to do with cable nomenclature. VGA cables (the analog 15 pin DIN connector as defined by the first VGA card from IBM back in the 80's) can be used for all of them. It think some manufactures use SVGA for cables that are rated for higher bandwidths. They give a clearer picture at high resolutions.
how do they measure bandwith. in other words wher ewould i look for thhe bandwith number on the case of the vga cable, or on a websitge in the description. its not in the description in websites
A good quality 15 pin SVGA cable will be fine, especially if it is less than 15 ft long
Cables longer than 15 ft need to be higher quality, low loss type -
the only ones i can find on websites are either 10 feet or 25 feet with nothing in between
vga and svga
By thejollypostman in forum Newbie / General discussionsReplies: 1Last Post: 9th Sep 2009, 18:36 -
laptop with only VGA to VGA-less HDTV
By liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 15:16 -
VGA to HDTV
By tweedledee in forum DVB / IPTVReplies: 16Last Post: 25th Sep 2008, 08:13 -
Should I use Component or VGA for HDTV?
By jdmbo1 in forum Media Center PC / MediaCentersReplies: 16Last Post: 22nd Sep 2007, 22:37 -
SVGA and VGA?
By warlock110 in forum ComputerReplies: 1Last Post: 11th May 2007, 20:07
