    Jan 2006
    India
    Hi,
    I am using powerdvd 6 for playing my dvds on pc but iam not satisfied with the audio.Its a bit low and especially is not audible from a distance especially the dialogues.Can anyone let me know about any audio enhancer or plugin for powerdvd.Thanks
    tryst20
    Nov 2002
    Buy the pro version
  3. Member Treebeard's Avatar
    Aug 2002
    what kind of sound card are you using?
    what kind of speakers are connected to computer?
    the above will greatly affect listening quality.
    Jan 2006
    India
    I am using soundmax 4 and creative vivid 60 as the speakers
  5. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Well, since you have a 2.0 speaker system, that explains the problem. DVDs use surround sound mainly 5.1, and it means your PowerDVD will downmixing the audio from 5.1 to 2.0 and hence you get the low and not very audible sound. I had the very same problem when I had a 2.0 system, until I upgraded to 6.1 speaker system.
    All I can suggest is you try alternative players and see if there is any difference is audible levels.
  6. Member olyteddy's Avatar
    Dec 2005
    I use power DVD ver 4, and have real good 2 channel sound. Have you tried all the audio config options?
  7. Turn off dynamic compression.
  8. Banned
    Nov 2006
    Beijing
    SPAM might be a good alternative.
    You are in breach of the forum rules and are being banned for spamming.
    / Moderator mats.hogberg
