this has been posted before but it wasnt specific,
Im getting the "unspecified error" when using nero7 with s2d 2.1.2284 and couldnt work out from the last post if nero 7 was compatible with version 2284 or 2294 ?
iam using 2.1.2284 and wont upgrade unless i have to
l********************** NEROBURNER *******************
18:25:21 DVD-Video files reallocation started
18:25:21 DVD-Video files reallocation completed (no file modified)
18:25:21 DVD-Video files sorted
18:25:23 Caching of files started
18:25:23 Caching of files completed
18:25:23 Burn process started at 2.4x (3,324 KB/s)
18:25:26 Unspecified Recorder Error
F: PIONEER DVD-RW DVR-107D
18:25:58 Generating DVD high compatibility borders
18:25:58 Unspecified Recorder Error
18:25:58 Could not perform end of Disc-at-once
18:25:58 Burn process failed at 2.4x (3,324 KB/s)
18:25:58 DVD NOT burned sucessfully
Chrissyboy had stated in a previous thread that it was compatible "with the latest realease." I would recommend you upgrade to the 2.1.2294 version and see if your problem goes away, I can't see any reason to be reluctant to do so.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Nero 7 is compatible with all versions of SVCD2DVD builds from the last 6 months or so. "Unspecified Recorder Error" would suggest that the drive identification is wrong somewhere. Can you burn the VIDEO_TS folder with Nero Express? If so what is the drive within Nero Express? In SVCD2DVD settings,is that drive an option?
nero works fine on its own, both burning rom and express - they both show the correct drives.
my burning drive is an option in svcd2dvd - works perfectly with copytodvd
but i get that error when processing a movie thru s2d with nero as the burner
i prefer nero..............might just update s2d and see if that works
thanks for the replies guys
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 23:43 -
Will the Nero LiquidTV Tivo remote bundle work on Vista MCE?
By yoda313 in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Nov 2008, 15:53 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
work-arounds for nero alphabetizing mp3 files
By Mustang.VxD in forum AudioReplies: 6Last Post: 9th Jul 2007, 00:54 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 14:07
