hello i ordered a new samsung Flat panel lcd hdtv and was just wondering about what hookups i should be using to get the best PQ. i have a comcast dvr cable box.
I know HDMI is the best connection for watching digital channels and high definition channels. What about standard definition analog channels, would i get better quality on SD using HDMI connections or using another connection. And if so, what connection is the best for this?
I have read that analog cable channels do not look so great using component/DVI/HDMI compared to using composite or S-video .... or better yet just using the "raw" RF and the tuner of the TV.
I have a Motorola cable box with Comcast cable and my analog channels look best from the "raw" RF using the tuner of my DVD recorder. I am sure it would be the same if I had the "raw" RF connected directly to the TV using it's tuner.
HDMI and DVI are great for digital sources, not analogue ones. RGB / YUV (Component) are the best alternatives for analogue
La Linea by Osvaldo Cavandoli
A lot of better large screen TV, has the appropiate filter on the analog hook up, to correct for color and noise in analog signal.
On my TV, cable looks better on RF in.
How can I get 1080 resolution from PC-HDTV without HDMI cable?
By leopardx in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2009, 08:41 -
Connecting XBOX 360 with 720p Plasma HDTV: So HDMI or Component Av Cable??
By jajabinks92 in forum DVB / IPTVReplies: 2Last Post: 29th Nov 2008, 09:16 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 21:37 -
Connect standard DVD player to HDTV with S Video cable?
By rocketman in forum Newbie / General discussionsReplies: 7Last Post: 13th Oct 2007, 02:33 -
Standard cable on hdtv...
By bla4free in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jun 2007, 23:35
