I wanted to ask since I am trying to burn 3 avi with 3 srts onto 1dvd. Should I be joining the 3avi into 1 avi, 3srt to 1 srt. Then extract video and audio separately to dvd compliant format. Or should I leave the avis and srt alone. Edit each episode alone to make sure that each episodes' video and audio are dvd compliant. Then I should use a dvd software that would let me set menus and burn 3 episodes onto 1dvd with subtitle.
I guess my question would be should I hardsub each episode and join them in the beginning and convert to dvd compliant format. Or should I softsub in the end using a good dvd software. Which one would be less problematic? Worried about out of syn sound, delayed sub etc.
If I need to join the srt with which program?
Thanks for your help
If it's one single movie I'd use AVI2DVD, as I just wrote a guide that explains how to do soft-switchable DVD subtitles with it.
However, you have episode stuff there... Hmmm... Not sure if AVI2DVD will be the best choice for you, unless you concat them first then set chapter points as the 3 separate episodes... Hmmm... Any one else have other suggestions? -
IF anyone can tell me how they burn dvds with multiple episodes of avis with srt.
I searched the forum found one way but it does not have subtitles
AVI to DVD MPEG(CCE or MPGen Encoder)
https://forum.videohelp.com/viewtopic.php?t=222898
The other one I found but once again no subtitles
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm
Thanks in advance. I am a newbie so nothing too difficult, steps or links would be appreciated. Thanks you for your patience -
2nd guide does not cover subtitles because that is job of authoring step
Multiple .srt subtitle files in a Divx movie
By sam9s in forum SubtitleReplies: 6Last Post: 13th Feb 2015, 16:34 -
Batch extract srt from multiple Mkv's?
By gosa in forum MacReplies: 59Last Post: 21st Apr 2012, 18:30 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 15:06 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
How do I name multiple srt files so that the language shows to select?
By JoeBolden in forum SubtitleReplies: 0Last Post: 29th Apr 2009, 14:02
