tools used
dvd2svcd 1.2.3.
d2sroba 3.8
cce 2.67
All of a sudden, my backups are not what they should be. What have I done? The final iso image is only 103 mb. Here are the logs:
log 1:
WNASPI32.DLL 0.0.0.0
- 4/15/2006 7:43:04 PM
- DVD to SVCD Conversion
- DVD2DVD ver. 1.2.3 build 1
Initializing
- F:\SHREK\VIDEO_TS\VTS_01_0.BUP
- F:\SHREK\VIDEO_TS\VTS_01_1.vob
- F:\SHREK\VIDEO_TS\VTS_01_2.vob
- F:\SHREK\VIDEO_TS\VTS_01_3.vob
- F:\SHREK\VIDEO_TS\VTS_01_4.vob
- F:\SHREK\VIDEO_TS\VTS_01_5.vob
- F:\SHREK\VIDEO_TS\VTS_01_6.vob
Initializing finished.
- 4/15/2006 7:43:07 PM
- DGIndex
Creating DGIndex INI file:
- C:\Program Files\DVD2SVCD\dgindex\DGIndex.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DGIndex.
Executing DGIndex. Commandline:
"C:\Program Files\DVD2SVCD\dgindex\dgindex.exe" -CS=2 -YR=1 -OM=0 -EXIT
-OF=[F:\movie files\DGIndex_Project_file]
-IF=[F:\SHREK\VIDEO_TS\VTS_01_1.vob,F:\SHREK\VIDEO_TS\V TS_01_2.vob,F:\SHREK\VIDEO_TS\VTS_01_3.vob,F:\SHRE K\VIDEO_TS\VTS_01_4.vob,F:\SHREK\VIDEO_TS\VTS_01_5 .vob,F:\SHREK\VIDEO_TS\VTS_01_6.vob]
Analyzing DGMPGDec Project file
Force Film activated!
Framerate: 23976
DGIndex processing done.
- 4/15/2006 8:06:50 PM
- Free on drive F: 25055.83 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: F:\movie files\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Audio extraction finished.
- 4/15/2006 8:40:43 PM
- Free on drive F: 24766.24 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 4666096988
AudioSectors: 307876548
VideoPAPO: 67511160
ScanOffsetBytes: 195012
SeqAligningBytes: 12394096
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 4278120168.00
Seconds: 5424.42
CalcMPEGStream: 4278120168.00
Frames: 130008
CDSize: 4464.00
Number of CDs: 1
Cut point 4460.00
Variable Settings:
Frames: 130008
Anti Noise Filter: Off
Passes: 3
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 2000
Max. bitrate: 8000
Avg. Bitrate: 6309
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\dgindex\DGDecode. dll")
MPEG2Source("F:\MOVIEF~1\DGINDE~1.D2V")
Import("C:\Program Files\DVD2SVCD\Tylo\RoBaConditional.avs")
LanczosResize(720,480)
Import("F:\movie files\ResampleAudio.avs")
ResampleAudio(44100)
ConvertToYUY2()
----AVS End----
- 4/15/2006 9:39:18 PM
Initializing
- Free on drive F: 20586.30 mb
- Restarting from: Pulldown
- 4/15/2006 9:39:21 PM
- Video Pulldown
Executing Pulldown. Commandline:
"C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "F:\movie
files\Encoded_Video_CCE_NTSC.mpv" "F:\movie files\Pulldown_Encoded_Video_NTSC.mpv"
-prog_frames p
Video pulldown finished.
- 4/15/2006 9:58:21 PM
- Free on drive F: 16508.40 mb
- Multiplexing Audio and Video
Executing MPlex. Commandline:
"C:\Program Files\DVD2SVCD\DVDAuthor\mplex.exe" -f 8 -o "F:\movie
files\MPlex_Muxed_File00.mpg" "F:\movie
files\Pulldown_Encoded_Video_NTSC.mpv" "F:\movie files\Extracted_audio_1.ac3"
- 4/15/2006 9:58:25 PM
- Free on drive F: 16497.38 mb
- Determining length of audio
Analyzing: F:\movie files\MPlex_Muxed_File00.mpg
23.040 seconds F:\movie files\MPlex_Muxed_File00.mpg
Analyzing finished.
- 4/15/2006 9:58:32 PM
- Authoring DVD
Executing DVDAuthor. Commandline:
"C:\Program Files\DVD2SVCD\DVDAuthor\dvdauthor.exe" -x "F:\movie
files\DVDAuthor.xml"
- 4/15/2006 9:58:35 PM
- Free on drive F: 16486.32 mb
- Creating DVD ISO Image
Executing MkIsoFs. Commandline:
"C:\Program Files\DVD2SVCD\DVDAuthor\mkisofs.exe" -o "F:\movie
files\DVDImage.iso" -publisher "DVD2SVCD" -volid "" -dvd-video "F:\movie
files\DVD-Files"
Image creation finished.
- 4/15/2006 9:58:37 PM
- Free on drive F: 16474.43 mb
- Conversion done!
log 2:
D2SRoBa v3.80, by Tylo
- WIN_XP - AutoIt 3.1.1.0
- 2006-04-15 19:42:08
- INI file : C:\Program Files\DVD2SVCD\Tylo\D2SRoBa.ini
- Output type : DVD
- CD size : 4464
- Sample file size : 1.0% (delete previous: Yes)
- Adjust estimated : 1.4% (accuracy tweak: Yes)
- Sizing pass : Encode (1 pass) if opv pass < -4.0% from
target, or Q > 40
Transcode (Requant) if opv pass > 0.0% above
target, and Q <= 40
- Cond. filtering : No
- Run mode : Normal
- Waiting for CCE window, or 'Ripping done' message box...
- Detected a CCE encode window
- Detected the movie encode window - shutting down
- 2006-04-15 20:41:37
- Copying D2SRoBa.ini to project dir F:\movie files\
- Avisynth setup: LanczosResize
- D2S ver. 1.2.3.1, CCE ver. 2.67.0.27
- Setting process priority 2
- Movie length : 01:30:22 (130008 frames, 23.976 fps)
- D2S audio select : 448 + 0 kbps
- D2S video calc. : 6309 kbps, 1 CDs
- Select ranges : every 1200, select 12 frames
- Sample frames : 1308
Calculations:
- 1 CD: video_br=6309 (6309) audio_br=448+0 video_sz=4276257882
fill=100% cbr=0
- Using num CDs : 1
- Target mpv br : 6309 (max 8000) kbps, size=4276257882 bytes
Search for Q:
- Sample enc. Q=14 : 4415 kbps, err=-30%, size=2992999803, sample
sz=30539888
- Sample enc. Q=7 : 6231 kbps, err=-1.2%, size=4223829327, sample
sz=43098992
- Determined Q : 7 = Round(7 + (-1.2/4.1)) with 1.4% adjustment.
- 2006-04-15 20:42:54
- Start movie OPV encoding (Q 7)
- OPV pass result: 101.8% on target, 6422 kbps (4352933416 /
4276257882) Speed: 1.92
- 2006-04-15 21:29:57
- Executing: "C:\Program Files\DVD2SVCD\Tylo\dist\Requant.exe" -level
98.24 -o "F:\movie files\Encoded_Video_CCE_NTSC.mpv" -i "F:\movie
files\Encoded_Video_CCE_NTSC.oversz.mpv" -auto -close
- Transcoding pass: 100% on target, 6308 kbps (4275994453 / 4276257882)
Speed: 9.76
- 2006-04-15 21:39:14
- Recover DVD2SVCD: Pulldown
- 2006-04-15 22:10:17
- D2SRoBa successfully finished
multiplexing produced a very small file! Here is the log:
INFO: [???] mplex version 2.0.0 (dvd2svcd modified) (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File F:\movie files\Pulldown_Encoded_Video_NTSC.mpv looks like an MPEG Video stream.
INFO: [???] File F:\movie files\Encoded_audio_1.ac3 looks like an AC3 Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (F:\movie files\Pulldown_Encoded_Video_NTSC.mpv)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 480
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Picture rate : 29.970 frames/sec
INFO: [???] Bit rate : 8000000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: AC3 Audio stream 00 (F:\movie files\Encoded_audio_1.ac3)
INFO: [???] AC3 frame size = 1536
INFO: [???] AC3 AUDIO STREAM:
INFO: [???] Bit rate : 49152 bytes/sec (384 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 8566496
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
**ERROR: [???] Can't find next AC3 frame: @ 9421824 we have 0000 - broken bit-stream?
Please help with backing up 360 games (ISO file is small)
By V Bot in forum ComputerReplies: 0Last Post: 13th Jan 2011, 22:27 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
Best app for HD-DVD to mkv conversion? With resulting file size around 4gb
By AndyD in forum Blu-ray RippingReplies: 1Last Post: 7th Apr 2009, 07:46 -
How to go from DVD to small MPEG file
By jester805 in forum Newbie / General discussionsReplies: 10Last Post: 17th Oct 2008, 19:15 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 21:39
