Hi.
Is it possible to get from a Xvid file to an DV-AVI file and the same size, as i started with.
I've captured my DV-avi file at a size at 400 mb, converted it to Xvid at a size at about 60 mb and now i want to get bact to the DV-avi file at 400 mb.
I've tried different codec i Vdubmod, but the file get to large, i end at about 3 GB.
Tommy
Results 1 to 15 of 15
I wouldn't recommend uncompressing a xvid. You're MUCH better off starting over with the original source.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I know, but its because i want to store it at a small size, so thart i don't have to edit all now.
I'll have 20 tapes with 90 minutes on, and if I should have all that on a harddrive it should be huge.
Tommy -
But if your original avi was 400mb why not recapture it and burn it to a cdr?
Because its a testfile.
The original file is 36 GB and i know i can compress it with Xvid to about 4.3 GB. so it fit on a DVD. -
Have you tried splitting it to several dvds??? I don't know if you can do that with avi. You should try though - its always best to preserve the original quality as much as possible - this wouldn' t be a problem though if you keep the original tape and don't erase it. Its just not ideal to work with xvid if you have a clean dv file transfer.
Install the Panasonic DV codec and you can then convert your Divx file back to DV. Given that DV is pretty much a constant bitrate codec, the size should be the same as the DV original. The quality, however, will not be. Compressing it down so much with Xvid throws away a lot of data that you cannot get back.
Read my blog here.
Ahhhhhh.
So the question really is this;
"I can compress a 400MB DV-AVI test file down to 60MB as XVID. I then want to know if I can convert this back to a 400MB DV-AVI file ?
Also, this is just a test scenario as it would then stand that I can compress a 36GB DV-AVI down to about 4.3GB to store on DVD and I want to be sure that I can expand this back to a 36GB DV-AVI when I choose to edit these further on down the track."
How's that ?
If that is the case, yes, install Panasonic DV Codec.If in doubt, Google it. -
Jimmalenko, you took the word right out of my mouthOriginally Posted by jimmalenko
Ive tried the Panasonic DV codec with no luck.
It says: Cannot start video compression. The source image format is not accetable. (error code -2) -
Ive tried to resize to 720 x 576, Xvid file is 640x480.Originally Posted by Baldrick
Got it going, just reinstalled Panasonic DV Codec and uninstalled Canopus DV Codec.
I can see a slight difference between original DV-avi and decompressed Xvid file, but that was expected.
But it will do.
Thanks for your help, much appriciated.
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 06:59 -
DV AVI vs TV card capture in AVI xvid
By fishywishy in forum Capturing and VCRReplies: 6Last Post: 29th Mar 2010, 17:54 -
lagarith avi to xvid avi - problem
By phpmysql348 in forum EditingReplies: 1Last Post: 23rd May 2008, 13:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
