Can anyone tell me if it is possible to re-record a sound track to an AVI vieo using VirtualDub. If so can you explain the steps, if not can you suggest a more suitable progam to use to accomplish what I want. ?
Well if its wav audio go to AUDIO - WAV AUDIO and you'll be able to insert the new track. I'm not sure how to do it with another audio type in virtualdub.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
VirtualDub Mod may be easier. Just go to 'Streams>Stream list' and click 'Add'. If you are replacing an existing audio, move your new one up and delete the old one. If you just want to mux it in use 'Direct stream' copy. If you want to convert it, use 'Full processing' and select your codec.
Thank you 'yoda313' and 'redwudz' for your replies. To 'redwudz' a further question to you answer - having done what you suggested, can you then play the AVI and re-record with eg microphone whilst the video is playing ?
If you are talking about putting in a 'voice over' track, not with VDM. But you can probably use the freeware audio editor Audacity for that. It accepts and outputs both WAV and MP3 audio.
It accepts several audio tracks or inputs at once. You could play the video with VD or another player, then with a microphone through the sound inputs, record the second channel with Audacity, then blend them together as wanted.
I've never tried it, but you may be able to play and record at the same time with Audacity by putting the sound track in there on one channel and plugging in a microphone for the other channel input. -
As redwudz said, it depends on what you mean by "re-record a sound track to an AVI video". If you mean a wholesale replacement (i.e. you have English-dubbed version, you want to replace it with original Chinese language version), then yes, as long as they're the same length and all that, and easier with VDubMod.
If you further changes, like take out the background music and replace with some othe rmusic, or take out the dialog, and so on, that's something else entirely. -
Thank you all who have offered solutions, if I explain in detail what I am trying to do then you will have a better idea of how to offer the best solution. I trying to produce a series of tutorials of a PC application using screen video capture program to record both my on screen movements and also a simultaneous voice commentary which I make whilst making the screen movements with the cursor. Sometimes I am successful first time but at other times whilst the video is OK, I have made several errors or stumbles in the commentary. In these cases I wish to replay the video and re-record the commentary whilst watching the replay and am looking for the best solution to achieve this.
Static image + audio track. Possible with VirtualDub?
By benquo in forum EditingReplies: 24Last Post: 19th Jul 2013, 09:07 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
Can VirtualDub record VHS tapes to AVI format?
By gregnovella in forum Capturing and VCRReplies: 4Last Post: 28th Apr 2009, 23:37 -
merge avi with double sound track
By facan in forum ffmpegX general discussionReplies: 11Last Post: 22nd Jun 2008, 16:29 -
No sound record
By journeyoftheanimals in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2008, 17:31
