Ok, if someone cares to share their advice with a newbie... I'm planning on buying a DVD-Rom Drive for my computer mainly for ripping DVDs, and want to keep it on the budget side. Up to now i've seen some generic drives around 12X, but I don't really know what I should be looking for.
If anyone could give me some advice as to what minimum requirements or specific characteristics i should consider, or what brands/models I should definitely avoid, how different characteristics affect performance etc... I would really appreciate it. Also (to save you all some time) if someone could direct me to a web source that covers the matter in a clear and comprehensive way, that would be really nice too.
ElTopo,
Please refer to the following topic: https://www.videohelp.com/phpBB/viewtopic.php?topic=71843&forum=11.
Opinion for best DVD-ROm's: Pioneer, LiteOn or BTC. Also, see http://www.cdrinfo.com (comparison).
hrm...i'm gonna hafta disagree with JJ_3_RIP on suggesting the BTC. they're not good. stick with either Pioneer's or Lite-On's 16x dvd-rom drives. they're relatively cheap at maybe $60-$70. however, the dvd-rom you should definitely avoid is toshiba, they can't rip anything over 2x.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
DVD-ROM Backup
By 329329 in forum Authoring (DVD)Replies: 2Last Post: 11th Mar 2010, 12:24 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03
